20 years agoProblem with CFI
hi
I follow the steps of this page http://nioswiki.jot.com/wikihome/operating...ms/compactflash (http://nioswiki.jot.com/wikihome/operatingsystems/compactflash) it can probe HD,but can't command it . here is the message of screen. ............... uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 003F0000 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6336k/8192k RAM, 0k/0k ROM (1282k kernel code, 478k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80481130 (irq = 1) is a jtag_uart dmfe_probe:eth0, 100000 Khz Nios <DM9000> eth0 I/O: 80481138, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 100000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: , ATA DISK drive arch/nios2nommu/kernel/irq.c(48): default irq handler vec=7 [0x7] ide0 at 0x80481000-0x80481007,0x80481038 on irq 7 hda: max request size: 512KiB hda: status error: status=0x58 { DriveReady SeekComplete DataRequest } ide: failed opcode was: 0x27 hda: drive not ready for command hda: 4278255360 sectors (2190466 MB) w/32640KiB Cache, CHS=65535/255/63 hda: status error: status=0x58 { DriveReady SeekComplete DataRequest } ide: failed opcode was: 0xef hda: drive not ready for command hda: cache flushes supported hda:hda: status error: status=0x58 { DriveReady SeekComplete DataRequest } ide: failed opcode was: unknown hda: drive not ready for command hda: set_geometry_intr: status=0x51 { DriveReady SeekComplete Error } hda: set_geometry_intr: error=0x00 { } ide: failed opcode was: unknown hda: recal_intr: status=0x51 { DriveReady SeekComplete Error } hda: recal_intr: error=0x00 { } ide: failed opcode was: unknown hda: task_in_intr: status=0x51 { DriveReady SeekComplete Error } hda: task_in_intr: error=0x00 { } ide: failed opcode was: unknown is there any suggestion?1 Reply
i just rebuild the kernel ,and it is working correctly.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
