21 years agoproblem with cable and ecos applications
I have some doubts. I will apreciate if someone can help me... Is there any problem if I use ByteBlaster II cable to run ecos applications on the board? I couldn't get the "hello world" messag...
21 years agoHello,
I read the discussion about the kinds of cables, and I think that this is my problem... I used the ByteBlaster II and ByteBlaster MV cables, and there was the same problem. <div class='quotetop'>QUOTE </div> --- Quote Start --- [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: starting in terminal mode only (Control-C exits)[/b] --- Quote End --- I'm using:[list][*]QuartusII 4.1 SP2 [*]Nios II - SP1 [*]ByteBlaster II and ByteBlaster MV [*]Stratix EP1S10-ES [/list] When I run the "program_flash hello" command, it occurs the message: Flash programming complete... done. When I download the NiosII processor from Quartus or some application from Nios IDE, there wasn't occurs any errors. Thanks, Maikon.
