13 years agoProblem with burstcount > 2 for Avalon MM Master to SDRAM
Hello, I am trying to implement a burst transcation with SDRAM using Avalon MM Interface. The following Verilog code works fine for burstcount = 2: module hw_det_3by3(
clk,
re...
13 years agoI would just simulate your design so that you can view everything to perform proper debug.
Although I'm not sure why the status bit does not assert, I think you want your count register to be two bits wide otherwise you will end up overriding the value in minor10 due to count register rolling over.
