20 years agoProblem with BuildrootGuide
i was following the BuildrootGuide but i encounter this problem when compiling the kernel. <div class='quotetop'>QUOTE </div> --- Quote Start --- ... LD init/built-in.o LD ...
19 years agoYes, there are some updates.
You should not use the build script in buildroot guide. You should change it and build cross gcc/uclibc only. Then use uClinux-dist to build kernel and apps.
