20 years agoProblem with BuildrootGuide
i was following the BuildrootGuide but i encounter this problem when compiling the kernel. <div class='quotetop'>QUOTE </div> --- Quote Start --- ... LD init/built-in.o LD ...
20 years agoi recently tried to build the toolchain in buildroot guide on my laptop. but i got this error:
<div class='quotetop'>QUOTE </div> --- Quote Start --- prepare uClinux-dist source patching file vendors/Altera/nios2nommu/config.arch patching file vendors/Altera/nios2nommu/config.vendor patching file vendors/Altera/nios2nommu/rc patching file vendors/Altera/nios2nommu/config.uClibc patching file vendors/Altera/nios2nommu/config.linux-2.6.x patching file vendors/Altera/nios2nommu/Makefile patching file .config patching file Makefile patching file user/clamsmtp/config.sub patching file user/clamav/config.sub patching file user/e2fsprogs/config.sub patching file user/ez-ipupdate/config.sub patching file user/radvd/config.sub patching file user/tcpdump/config.sub patching file user/ip-sentinel/config.sub patching file user/rsync/config.sub patching file user/ntp/config.sub patching file user/tcsh/config.sub patching file user/bind/config.sub patching file user/bind/contrib/nslint-2.1a3/config.sub patching file user/bind/contrib/idn/idnkit-1.0-src/config.sub patching file user/traceroute/config.sub patching file user/frox/config.sub patching file user/appWeb/conf/config.sub patching file user/nessus/nessus-plugins/config.sub patching file user/nessus/libnasl/config.sub patching file user/nessus/nessus-core/config.sub patching file user/nessus/nessus-libraries/libpcap-nessus/config.sub patching file user/nessus/nessus-libraries/config.sub patching file user/smtpclient/etc/config.sub patching file user/samba/source/config.sub patching file user/squid/cfgaux/config.sub patching file user/gdb/config.sub patching file user/gdb/readline/support/config.sub patching file user/grep/config.sub patching file user/ssh/config.sub patching file user/net-snmp/config.sub patching file user/speedtouch/config.sub patching file user/openvpn/config.sub patching file user/stunnel/auto/config.sub patching file user/lirc/config.sub patching file user/setserial/config.sub patching file user/zebra/config.sub patching file user/wget/config.sub patching file user/ulogd/config.sub patching file user/arj/gnu/config.sub patching file user/strace/config.sub patching file user/dropbear/config.sub patching file user/dhcpcd-new/config.sub patching file user/lrzsz/config.sub patching file user/asterisk/editline/config.sub patching file user/rrdtool/config.sub patching file user/at/config.sub patching file user/mysql/config.sub patching file user/snort/config.sub patching file user/bash/support/config.sub patching file user/proftpd/config.sub patching file user/proftpd/lib/libltdl/config.sub bzip2: (stdin) is not a bzip2 file. tar: Child returned status 2 tar: Error exit delayed from previous errors ./build: line 39: cd: /home/jwlam/buildroot: No such file or directory can't find file to patch at input line 5 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |Index: toolchain/uClibc/uClibc.config |=================================================================== |--- toolchain/uClibc/uClibc.config (revision 14578) |+++ toolchain/uClibc/uClibc.config (working copy) -------------------------- File to patch: [/b] --- Quote End --- i cant remember getting this when i do on my desktop. hippo pls help. thx.
