20 years agoProblem with BuildrootGuide
i was following the BuildrootGuide but i encounter this problem when compiling the kernel. <div class='quotetop'>QUOTE </div> --- Quote Start --- ... LD init/built-in.o LD ...
20 years agothx for ur help hippo.
i did wat u suggest n the make terminated as below: <div class='quotetop'>QUOTE </div> --- Quote Start --- make[2]: Entering directory `/home/jwlam/uClinux-dist-test/user/cgi_generic' romfs-inst.sh /home/jwlam/uClinux-dist-test/vendors/Generic/httpd /home/httpd 2 blocks romfs-inst.sh /home/httpd/cgi-bin/cgi_demo cp: cannot create regular file `/home/jwlam/uClinux-dist-test/romfs/home/httpd/cgi-bin/cgi_demo': No such file or directory make[2]: *** [romfs] Error 1 make[2]: Leaving directory `/home/jwlam/uClinux-dist-test/user/cgi_generic' make[1]: *** [romfs] Error 2 make[1]: Leaving directory `/home/jwlam/uClinux-dist-test/user' make: *** [romfs] Error 1[/b] --- Quote End --- so i manually create tat folder n make again. it terminated successfully. there is nth for me to copy from bin, usr n var folder. but i copy the romfs/httpd folder to rootfs/home/httpd after downloading the image onto my board, boa is running well, i can view the index.html. however, when i access cgi-bin/cgi_demo, i got a 404 Not Found error. did i do anything wrong? Pls advise. Thx again!
