13 years agoProblem with asynchronous reset and booting
Hello I have the NIOS configured to boot the boot from the on-chip memory. The first time successful startup. When you reset the NIOS using asynchronous reset signal the BOOT not load a softwa...
12 years agoWhat code do you have in this BOOT memory? If it changes, then it means that at some point your software writes to this section. If you enable the CPU with hardware breakpoints, I think you can make it stop when it tries to write something to that location. (I've never tried this though, so I can't help you set it up)
