20 years agoProblem with application w3cam
Hi, I compiled the kernel with application w3cam (Kernel/library/defaul tselection->Customize Vendor /User Settings->Miscellaneous Applications->Video tool->vidcat).I have selected Building lib...
20 years agoHi, Ankur
I copy all *.h file needed (libpng,libz,libjpeg) in the dir /home/leewood/uClinux-dist-test/uClibc/include. And then I modify flags: " LDFLAGS="$LDFLAGS -L/usr/local/lib -L/usr/local/X11/lib" CFLAGS="$CFLAGS -I/usr/local/include "" into "LDFLAGS="$LDFLAGS -L/home/leewood/uClinux-dist-test/ib -L/usr/local/X11/lib" CFLAGS="$CFLAGS -I/home/leewood/uClinux-dist-test/uClibc/include " in configure.in file . The configure.in file as follow: AC_INIT() AC_ISC_POSIX Makefile is generated automatically from Makefile.in by configure. The Makefile.in like this: CC = @CC@ prefix=@prefix@ exec_prefix=@exec_prefix@ sbindir=@sbindir@ cgibindir=$(prefix)/cgi-bin bindir=@bindir@ VERSION=0.7.2 CFLAGS = @CFLAGS@ @DEFS@ -DVIDEO_DEV=\"@ac_device@\" -DVERSION=\"$(VERSION)\" LDFLAGS = @LDFLAGS@ LIBS = @LIBS@ OBJ = w3cam.o cgi.o v4l.o default: w3cam.cgi vidcat vidcat.1 README ppmtoascii w3camd/w3camd w3cam.cgi: $(OBJ) $(CC) $(LDFLAGS) -o $@ $(OBJ) $(LIBS) vidcat: vidcat.o v4l.o $(CC) $(LDFLAGS) -o $@ vidcat.o v4l.o $(LIBS) ppmtoascii: ppmtoascii.o $(CC) $(LDFLAGS) -o $@ ppmtoascii.o w3camd/w3camd: cd w3camd && make install: w3cam.cgi install w3cam.cgi $(cgibindir)/ test -f $(cgibindir)/w3cam.cgi.scf || install w3cam.cgi.scf $(cgibindir)/ install vidcat $(bindir)/ install vidcat.1 $(prefix)/man/man1/ vidcat.1: vidcat.man sed "s/VERSION/$(VERSION)/" < vidcat.man > vidcat.1 clean: rm -f *.o w3cam.cgi vidcat ppmtoascii cd w3camd && make clean && rm -f w3camd msproper: clean rm -f config.status config.log config.cache Makefile index.html: index.in sed "s/@VERSION@/$(VERSION)/" < $< > $@ README: index.html lynx -dump http://www/~rasca/w3cam/index.html (http://www/~rasca/w3cam/index.html) | sed "s%/www/%/home.pages.de/%g" > README tarball: msproper cd .. && tar -czvf w3cam-$(VERSION).tar.gz w3cam-$(VERSION)/ The error is the same as before. I think I have done incorrectly to add INCLUDE path of dir where all *.h files are present . How to do it??? And I do not understand the flag "-l" ("-I" is the option in your gcc include flag, current path is only -I/home/leewood/uClinux-dist-test ),What dose it mean? Pls give me some advice.Thanks --leewood
