21 years agoProblem with “Flash Problem”
Hello, The Flash Programmer can’t access my custom board. The error message is as follows: “There is a problem with the target board. Check the target board selection in SOPC Builder for t...
21 years agoHello morten_tor,
Thank you for your tips. Unfortunately this will not help because the error comes up before the button “Program Flash” is activated. And the board was running exactly in this configuration. I don’t know why there are problems now. Yesterday I figured out then when the SOPC Builder is open sometimes the error message does not appear and programming the flash does work. Bye, niosIIuser
