12 years agoProblem while doing SoCkit_SW_13.0 lab
I've downloaded the 'SoCKIT_Materials.zip' and do the involved labs: SoC_HW_Lab_13.0 and SoC_SW_Lab_13.0. I had problems when debugging the preloader in the SW lab:
when start debugging(click the debug button in DS-5), it first goto the reset instruction of the start.S file: reset: bl save_boot_params , then jump to the save_boot_params function of the lowlevel_init.S file: /* Save the parameter pass in by previous boot loader */ .global save_boot_params save_boot_params: # ifdef CONFIG_SPL_BUILD# if (CONFIG_PRELOADER_DEBUG_MEMORY_WRITE == 1) /* * write the debug memory header and value of R0 - R3 (which passed * by BootROM) into debug memory region (which is on ocram) */ ldr r5, =CONFIG_PRELOADER_DEBUG_MEMORY_ADDR ldr r4, =PRELOADER_DEBUG_MEMMORY_HEADER stmia r5!, {r4} stmia r5, {r0 -r3} /* get the reset manager status register passed by BootROM */ add r5, r0,#0x34 ldr r4, =rst_mgr_status ldr r5, [r5] str r5, [r4]# endif /* CONFIG_PRELOADER_DEBUG_MEMORY_WRITE */ My first debug always halted at the 'ldr r5, [r5]' instruction. Then click the reset button(back to entry point) to do re-debug, and it can work correctly. Any one knows why? BTW, my quartus is version 13.1, and DS-5 is 5.15.0.1 Reply
The problem has been solved. I found a new lab material for quartus 13.1:
http://www.rocketboards.org/pub/documentation/arrowsockitevaluationboard/sockit_materials_13.1.zip
