16 years agoProblem while compiling NIOSII application to be loaded into DRAM from FLASH
Hi, I am writing a custom boot loader + an application. The bootloader will run from onchip-ram and will copy application,which needs to be stored in CFI flash, to DRAM. Reset & exception ...
16 years agoThe error is a call instruction that needs to change the highest 4 bits of the address - probably a call from on-chip memory to SDRAM.
You can make the code work by using an indirect call. But you probably want to have the irq entry point into the 'bootloader' and have the application register it's own function. That means you probably don't want the code from alt_irq_handler.c in your application.
