13 years agoProblem when reload a Qsys design on Nios IDE 12.1
Hello, I have several errors on NIOS IDE when I modify design on Qsys and reloading the system. I use the Quartus II 12.1 with Qsys and NIOS IDE. So basically when I created a new design on Qsys w...
13 years agoFinally i found the solution with a colleague. So i post the solution for the community.
In fact it's simple. The problem (for me) is when i start NIOS IDE i choose my workspace on my hard disk (for exemple D:\Quartus121) but you have to indicate the way to your project, for exemple D:\Quartus121\Project\Test_Project_Nios if not NIOS IDE didn't reload the .qsys correctly... I hope it can help some altera member.
