Problem when downloading zImage to DE2-115 (cont.)
Yes, sorry, there's a SDRAM at 0x00000000 so it should be working. If it can't write to the memory and read the same content (verify) it means your memory is not working properly. Your design seems to be missing a clock to your SDRAM. You should add a PLL to generate a clock to your SDRAM. Please take a look at the projects found in the board CD-ROM (you can download it from Terasic site). You will find the right PLL configuration and other valuable information in these reference designs.
I've tried to design it with UP clocks that comes from Altera University program. But it did not work. Strange thing is that i can not even download zImage to board again. The error is the same as i had before.
I also attached the design that produces that output.Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused - Altera_Forum
Sorry, I don't know what you mean by "UP clocks".
I've just added the PLL and connected the clock output to the DRAM_CLK pin PIN_AE5 (from DE2-115.qsf file available in Terasic site). The SDRAM is working now. There only difference from your project is the Qsys file and the pin assignment. The pin assignment is shown below and the new Qsys file is attached. I've successfully run uCLinux and though I can't sent you my zImage I guess yours should work too.
Please note that this design is far from good, it should at least have a SDC file. Though the design is now working, I want to make sure you understood what happened here so you can do it by yourself when you need.set_location_assignment PIN_AE5 -to DRAM_CLK - Altera_Forum
I believe i did the work as you said. But even so it still did not work. I've attached files.
I started to believe my zImage may be somehow broken or make progress fails even it generates zImage in /uClinux-dist/linux-2.6.x/arch/nios2/boot directory. - Altera_Forum
It seems that i don't know how to compile from .qsys and generate .sof file. Because i am able compile and build these files and got .sof file. But it does not work. But your file which you've send me works smoothly. So, could you please explain me step by step what to do in compilation and build stage ?
Actually I did the following steps, you can try to do it and see what you get.
1. Open the project you posted, onur.qar 2. Copy Qsys project you posted, inside quartus1.tar, to the project directory, where onur.qpf is located 3. Edit your Qsys system in order to add a PLL. You can see the specs and connections I used or just use the Qsys I posted. You will export a pll output so your system will have an additional pin. 4. Generate your system. Make sure the path where the system will be generated is the same of the .qip file you added to your Quartus project. 5. Elaborate your project. Open the pin planner. Assign the newly created pin to PIN_AE5, which is the memory clock pin. 6. Compile your project. I'm attaching my .sof with the working memory for you to make sure you zImage is working. - Altera_Forum
Thank you. I managed to download and made it verify succesfully. But now it seems there is no filesystem to mount. Have you encountered that ?
root@F15:~/altera/12.1/nios2eds/bin# ./nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 3.7.0-01377-g1061bd7-dirty (root@F15) (gcc version 4.1.2)# 16 Thu May 9 11:05:35 EEST 2013 bootconsole enabled early_console initialized at 0xe8001440 On node 0 totalpages: 32768 free_area_init_node: node 0, pgdat c02faac0, node_mem_map c0310780 DMA zone: 256 pages used for memmap DMA zone: 0 pages reserved DMA zone: 32512 pages, LIFO batch:7 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory available: 126776k/3130k RAM (2387k kernel code, 742k data) NR_IRQS:64 Calibrating delay loop... 23.45 BogoMIPS (lpj=46912) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 NET: Registered protocol family 16 bio: create slab <bio-0> at 0 Switching to clocksource timer NET: Registered protocol family 2 TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 247 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) ttyJ0 at MMIO 0x8001440 (irq = 1) is a Altera JTAG UART console enabled, bootconsole disabled console enabled, bootconsole disabled mousedev: PS/2 mouse device common for all mice TCP: cubic registered NET: Registered protocol family 17 List of all partitions: No filesystem could mount root, tried: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) - Altera_Forum
I'm sorry, I've never had this problem. But I think I've seen it before on forums and all over the internet. I guess you'll find the answer easily.
I'm pretty sure you have something wrong in your kernel configuration, but I don't know how to help you here. - Altera_Forum
I got it work ! The problem about rootfs is that there is no rootfs that is called after kernel initialization. I included .cpio file into my kernel then problem disappeared.
Thanks, I really appreciated your contribution. New problem arised that I am able to compile the .sof file but after that i can not download my zImage in to the board. Weirdly, my design that compiled by you works smoothly. I tried to compile .sof file in my Windows machine too. But result remains same. Have you any idea about it ?
