22 years agoProblem when download to Board
Hello
I'm a newbe with nios. I have a devolement board, with a nios cyclone cpu. When I want to download uClinux for my board it write this: [SOPC Builder]$ nr linux.srec nios-run: Ready to download linux.srec over COM1: at 115200 bps nios-run: Downloading.# 0300: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF# ................ # .................# 0380: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF# ................# ect. ect. ect. It just continue forever. I don't have any problem when I download uC/OS-II. What can be wrong?? Best regards Jimmi Wolff2 Replies
Jimmi,
What version of the Linux Develper CD are you using and are you using the core that was supplied with it? What type of Dev Board do you have? Can you post the first few lines of your SREC? mike - Altera_Forum
Hello
I have a Nios Development Kit, Cyclone Edition. And I don't use the Linux Develper CD from microtronix. Here is the first lines of the SREC file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can't not even convert the srec file to a flash file. It look like this when i try:[sopc builder]$ srec2flash linux.srec
flash address: 0x00140000
ram address: 0x00040000
max copy size: 0x00040000
file 0: linux.srec
linux.srec spans from 0x00800000 to 0x00881000 (0x00081000 bytes)
building linux.srec.copier.srec
c:\cygwin\bin\perl.exe (1444): *** wfso timed out after longjmp
7 [main] perl 1756 fork_copy: user/cygwin data pass 3 failed, 0x22ecc0..0x
230000, done 0, windows pid 1444, win32 error 5
I hope someone can help, though I don't use uclinux from microtronix. Best regards Jimmi Wolff
