17 years agoProblem using the CompactFlash
Hi, I'm trying to use the compact flash on my 2c35 DE board. I have done everything on the wiki page (http://www.nioswiki.com/operatingsystems/uclinux/compactflash) (even example code at the ...
17 years agoWith a new hardware design, you should debug the hardware first. Add a small loop reading writing the CF registers. You can use signaltap to verify the io timing.
- Hippo
