17 years agoProblem using SOPC builder
Hello all!
I am trying to open a predefined project (de2_net). when opening the SOPC builder, it gives an error "Warning: isp1362_0: Used isp1362 1.0instead of 1.0.1)" I am using 9.0 version.. can any1 tell me how to get rid of it .. I m new to this system Thank you !!1 Reply
<div class='quotetop'>QUOTE (singh0601 @ Aug 30 2009, 03:45 PM) <{post_snapback}> (index.php?act=findpost&pid=23682)</div>
--- Quote Start --- Hello all! I am trying to open a predefined project (de2_net). when opening the SOPC builder, it gives an error "Warning: isp1362_0: Used isp1362 1.0instead of 1.0.1)" I am using 9.0 version.. can any1 tell me how to get rid of it .. I m new to this system Thank you !![/b] --- Quote End --- Hello, SOPC builder simply tells you that it uses version 1.0 of the isp1362 component, instead of version 1.0.1. This is probably because your project was made with a version prior to 9.0. However, that should be no problem. To get rid of this warning, try deleting the component instance (isp1362_0), then add it again. It should update the SOPC builder info file with the latest component version. Hope this helps. Regards
