21 years agoProblem using SDRAM
Hello, I have problem using SDRAM on my custom board. My program won't run when I map program memory(.text) to SDRAM. I have no trouble reading/writing SDRAM from my program if .text...
19 years agoMy advice is to remove the parallel flash and to use the EPCS flash to store software. The board will be cheaper and simpler this way.
The serial flash is fast enough, we get 1.1MB/s transfer for the software. You can use serial flashes from other manufacturers: http://forum.niosforum.com/forum/index.php...14&hl=signature (http://forum.niosforum.com/forum/index.php?showtopic=3814&hl=signature) IzI
