21 years agoProblem using SDRAM
Hello, I have problem using SDRAM on my custom board. My program won't run when I map program memory(.text) to SDRAM. I have no trouble reading/writing SDRAM from my program if .text...
21 years agohello!
i have a very similar problem, my code is not running from my external RAM (SSRAM) and i am using a custom board. i cud not follow how u solved the problem, can u please explain what i should do to get it working. my opcode fetches are happening fine, but the stack pointer (fp) is pointing to an absurd address location. Thanks in advance, Raghu
