21 years agoProblem using HAL Api
Hello, I have problem using HAL api.. I just want to open device using alt_flash_open_dev() just like in "Simple Flash Access" of "The HAL Api Reference", but it always returns 0x0. Do...
21 years agoThank you rugbybloke, I appreciate your response.
I am still suffering the problem. I am calling: alt_flash_open_dev("/dev/ext_flash"); system.h has:# define EXT_FLASH_NAME "/dev/ext_flash" So, I think I have the name right. I toggled few break points in alt_find_dev(). There seems to be no device registered in the alt_llist* list. For this reason, I tried calling alt_sys_init() right before alt_flash_open_dev(). when I did this, the devices then seem to be registered in the list. Using memory dump, I found below devices in the list: /dev/ext_flash, /dev/epcs_controller, /dev/jtag_uart, /dev/uart1, /dev/null but still, alt_flash_open_dev() fails, & returns 0x0 (I am still checking why this happen). Am I getting any closer? or totally going the wrong way...?
