20 years agoProblem using Flash Programmer
Hello, I have problem using Flash Programmer. I am trying to write something to flash of my custom board, but doesn't seem to work.. Below message appears: ---------------------...
20 years ago --- Quote Start --- originally posted by fuji@Oct 6 2005, 08:03 AM hello,
i have problem using flash programmer.
i am trying to write something to flash of my custom board,
below message appears:
[sopc builder]$ nios2-flash-programmer --input=xxx_fpga.flash --sof=d:/doors_h ome/xxx/xxx_board/system/xxx_board.sof --base=0x00800000
warning: default charset ms932 not supported, using iso-8859-1 instead oct 6, 2005 8:32:57 pm - (??) nios2-flash-programmer: launching quartus program er to download:
d:/doors_home/xxx/xxx_board/system/xxx_board.sof
oct 6, 2005 8:33:01 pm - (???) nios2-flash-programmer: error opening target har ware
oct 6, 2005 8:33:01 pm - (???) nios2-flash-programmer: unable to open flash-
evice after successfully communicating
with target.
it is likely that you are using a flash-programming fpga design which was not created for your target board.
i think i am not doing totally wrong,
since i can write something into epcs using nios2-flash-programmer,
and it seems to work just fine.
any advice will be great.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10191)
--- quote end ---
--- Quote End ---
