20 years agoProblem to run the Hello example
I'm newbie, I'm trying to run the Hello World sample I have a NiosII Evaluation Kit The 'NIOS II IDE' is version 1.1.0 I have already sent the file .../niosII_cyclone_1C12_eval/standard/standard_eval_board.sof on the board using QuartusII Programmer V4.2 It was succesfull. When I start the nios2-terminal, it works. I'have build the example -> OK I try to run it and I have the following error -------------------------------------------------- Using cable "Nios II Evaluation Board [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x021208B8: does not match ID value does not match: read 0x14400B2E; expected 0x2FF81C2D Timestamp value does not match: image on board is newer than expected Read timestamp 13:10:34 1906/03/20; expected 9:45:02 2004/11/25 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor -------------------------------------------------- What does it mean and what have I to do ? Where can I find a good faq ? Is it possible to perform a search on the forum ? Thanks a lot Best regards3 Replies
hi,reproduce your project and make sure your selected the right ptf file,make sure the ptf file according to the downloaded hardware configure file (sof or pof).
Thank for these answer.
I'will check it asap. I'll give you a feedback
