20 years agoProblem starting up linux on Nios II Cyclone
Hi everybody, despite my earlier post I now have a big problem with trying to start linux. The kernel and filesystem compile ok, with a few warnings on the way. What I get when I try to log on throug...
20 years ago --- Quote Start --- originally posted by repa@Jun 14 2006, 01:18 PM so... after a few false starts i tried working on linux. the results weren't that great either. first of all, "make menuconfig" didn't work. it just stopped after a few lines and despite waiting patiently for something like 10 minutes, nothing happened. "make config" at least went further, but it didn't let me customize the kernel settings. also, linux_hwselect probably didn't work either, because, despite running it ok, i got errors later on declaring i should run it.
too bad i'm running so short on time, otherwise i would try setting up a different linux distro to work on, as i'm suspecting something fishy is going on with the os...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16166)
--- quote end ---
--- Quote End --- I tried to compile nios2 uClinux without problem on coLinux. http://nioswiki.jot.com/wikihome/operating...ux/nios2colinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/nios2colinux)
