Problem running ModelSim
Hello, I have just install Ubuntu 14.04 64 bit in my computer and I have install Quartus 2. It works well but I canꞌt use ModelSim, I recieve an error that says:
Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Check the NativeLink log file And the content of this file is: Info: Start Nativelink Simulation process Info: NativeLink has detected Verilog design -- Verilog simulation models will be used ========= EDA Simulation Settings ===================== Sim Mode : RTL Family : cycloneii Quartus root : /home/juan/altera/13.0sp1/quartus/linux/ Quartus sim root : /home/juan/altera/13.0sp1/quartus/eda/sim_lib Simulation Tool : modelsim-altera Simulation Language : verilog Simulation Mode : GUI Sim Output File : Sim SDF file : Sim dir : simulation/modelsim ======================================================= Info: Starting NativeLink simulation with ModelSim-Altera software Sourced NativeLink script /home/juan/altera/13.0sp1/quartus/common/tcl/internal/nativelink/modelsim.tcl Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: issued_nl_message Nativelink TCL script failed with errorInfo: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. while executing "error "$emsg" "" "issued_nl_message"" invoked from within "if [ catch {exec $vsim_cmd -version} version_str] { set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..." (procedure "launch_sim" line 89) invoked from within "launch_sim launch_args_hash" ("eval" body line 1) invoked from within "eval launch_sim launch_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error $result $savedInfo $savedCode } else { ..." invoked from within "if [catch {eval launch_sim launch_args_hash} result ] { set status 1 if [ info exists ::errorCode ] { set savedCode $::errorCode set sav..." (procedure "run_sim" line 78) invoked from within "run_sim run_sim_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error "$result" $savedInfo $savedCode } else { er..." (procedure "run_eda_simulation_tool" line 330) invoked from within "run_eda_simulation_tool eda_opts_hash" I'm new using Quartus in ubuntu so I'm a little lost, I would be grateful if you can help me. I've been looking for solutions on google and but I have not found a lot. I found something about removing the .altera folder but it doesn't work for me. Thank you.5 Replies
It looks like you installed the non-free Modelsim Altera version (with mixed VHDL/Verilog capability). You probably want to install the free Altera Starter Edition (which doesn't support mixed VHDL/Verilog simulation) and doesn't need a license file
Thank you very much for your answer. I installed the free version but I have reinstalled it again and I get the same error, the project I used was only Verilog and I could simulate it in Windows. I tried to give all the permissions to the install folder of modelsim but the error is still the same. Thank you for your help!
--- Quote Start --- Thank you very much for your answer. I installed the free version but I have reinstalled it again and I get the same error, the project I used was only Verilog and I could simulate it in Windows. I tried to give all the permissions to the install folder of modelsim but the error is still the same. Thank you for your help! --- Quote End --- Hi I have the same problem and same error on Ubuntu 14.04 64bit, Quartus 13.0 works well (subscription edition, with a network license), but not MultiSim-Altera, either Starter Edition or Normal Edition. On my previous Ubuntu 12.04 32bit, everything worked perfectly. - Altera_Forum
hello, I'm facing the same problem and I would like a help
I use Linux Mint 17 - 64 bit, I've installed 32 bit libraries but ModelSim still does not work. - Altera_Forum
I am having similar problems trying to run ModelSim-Altera Starter version 14.1.0.186 on Windows 7. See attachments.
