20 years agoProblem running menuconfig utility
hi I am using Quartus2 v5.0 and Nios2 v5.0. At the end of the installation of Microtronix linux, I got a message that cygwin could not locate /usr/include. I did not know how to fix it. While try...
20 years agoManually running the install_cyg_ext.sh script (per this thread) solved a problem I was having as well:
- install tools - create new kernel project - run Configure Kernel Result - Dos/Cygwin window appears for a half second and then dissapears I ran the script directly from the Nios II SDK Shell and it seems to be working now. (Possible search topics - Can't configure kernel, Kernel Configuration problem)
