15 years agoProblem rebooting Nios II from uClinux
Dear all,
I need to reset Nios II from uClinux. I tried to use "reboot" app from sash but it didn't work. The response isRestarting system and then system freezes. I'm working on a Stratix II EP2S60. I tried to reset using "CPU RESET" button, but with the same result. I tested the button on a simple program without OS and it works, so it's a uClinux problem. I hope you can help me, thanks in advance Marco14 Replies
Ok guys, thanks for your replies, I agree with you. Now I'm focusing on how to run uClinux from flash. I followed the wiki's article "Flash Programmer", but it doesn't work. I was able to store .sof in flash and it works. The problem is when i try to store zImage.
Step followed: 1. nios2-configure-sof <file>.sof 2. sof2flash --offset=0xC00000 --input=<file>.sof --output=<file>.flash 3. nios2-flash-programmer --base=0x02000000 <file>.flash 4. elf2flash --base=0x02000000 --end=0x02ffffff --reset=0x02000000 --input=zImage --output=ext_flash.flash --boot =SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec 5. nios2-flash-programmer --base=0x02000000 ext_flash.flash My Flash base address is 0x02000000 and its size is 16 MBytes. In vendor_hwselect i selected sdram in "Please select device to execute kernel from", the Reset Vector is located in ext_flash at the base address (0x02000000), exception vector in sdram (0x00000020). The problem is that kernel doesn't start. If i press CPU reset botton i can see the LEDs on the LAN turn off and on again after a certain period, so it seems to be right because i set up LAN in rc file, but i can't ping the board and i cannot see anything on hyperterminal. - Altera_Forum
Finally it works. I made some mistakes, but the most important was in "Link Address offset for booting", i had to change it to a bigger value. Thanks a lot for your support.
Marco - Altera_Forum
Ok fine.
But the steps 1-5 you described above were right? Because I couldn't see any mistake in the commands. Urmel - Altera_Forum
Yes they were right, but initially I had the wrong address reset (0x00000000 instead of 0x02000000, i've edit a previous post).
