15 years agoProblem rebooting Nios II from uClinux
Dear all, I need to reset Nios II from uClinux. I tried to use "reboot" app from sash but it didn't work. The response is Restarting system and then system freezes. I'm working on...
15 years agoOk guys, thanks for your replies, I agree with you. Now I'm focusing on how to run uClinux from flash. I followed the wiki's article "Flash Programmer", but it doesn't work. I was able to store .sof in flash and it works. The problem is when i try to store zImage.
Step followed: 1. nios2-configure-sof <file>.sof 2. sof2flash --offset=0xC00000 --input=<file>.sof --output=<file>.flash 3. nios2-flash-programmer --base=0x02000000 <file>.flash 4. elf2flash --base=0x02000000 --end=0x02ffffff --reset=0x02000000 --input=zImage --output=ext_flash.flash --boot =SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec 5. nios2-flash-programmer --base=0x02000000 ext_flash.flash My Flash base address is 0x02000000 and its size is 16 MBytes. In vendor_hwselect i selected sdram in "Please select device to execute kernel from", the Reset Vector is located in ext_flash at the base address (0x02000000), exception vector in sdram (0x00000020). The problem is that kernel doesn't start. If i press CPU reset botton i can see the LEDs on the LAN turn off and on again after a certain period, so it seems to be right because i set up LAN in rc file, but i can't ping the board and i cannot see anything on hyperterminal.
