20 years ago
Problem on JTAG ID code
I am using Altera DSP Development Kits(Stratix II 2S60).
Do Nios II Linux v1.4 support it? If so, where can I find the appropriate source code for it?
I use Nios II Linux Distribution v1.4 now. However only codes for Stratix II 2S60ES available after setup. When I use them on my board. An error message appears:
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
Dec 30, 2005 3:19:27 PM - (??) nios2-flash-programmer: Launching Quartus Program
mer to download:
c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es/syste
m/altera_nios_dev_board_stratix_2s60_es.sof
Error: Can't configure device. Expected JTAG ID code 0x020930DD for device 1, bu
t found JTAG ID code 0x120930DD.
Error: Operation failed
Error: Quartus II Programmer was unsuccessful. 2 errors, 0 warnings
Dec 30, 2005 3:21:34 PM - (??) nios2-flash-programmer: Unable to download SOF: c
:/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es/system/alte
ra_nios_dev_board_stratix_2s60_es.sof, exiting
Is there any way to fix it? Or change the JTAG ID code to 0x120930DD?
    The qii5.1 and nios5.1 are released.
    Update to them. There are a lot of bugs fixed.
    There are samples about multithreading under
    altera\kits\nios2_51\examples\software\linux\apps\samples\thread
