20 years agoProblem on JTAG ID code
I am using Altera DSP Development Kits(Stratix II 2S60). Do Nios II Linux v1.4 support it? If so, where can I find the appropriate source code for it? I use Nios II Linux Distribution v1...
20 years agoI found the problem may be caused by altera_nios_dev_board_stratix_2s60_es.sof (under C:\altera\kits\nios2\components\altera_nios_dev_board_stratix_2s60_es\system)
When I upload the file named "vmlinux.bin", firstly, the above sof file will be downloaded to the board. This time, I use the sof file for 2s60 (from example "hello world") instead of that one. No JTAG error appears. The sof file downloaded succusfully. Hence I think the most important thing is to find the right sof file for uCLinux to 2S60. Anyone have the project file or SOF file? I can rebuild it by myself. Or can send to me. Regards Yueran
