21 years agoProblem of Porting Flash Programmer.
Hello Everyone, I use Microtronix Cyclone Development Board(I think it is a bad dev board, so many important part generated by SOPC Builder Core can not work with Nios II) and it is just a c...
21 years agoWhat do you mean by you "leave the clock and reset pins unassigned"? I'm not familiar with the Microtronix Dev. Kit, but your Flash Programmer design (created by mk_target_board) doesn't have any chance of working without a clock and reset. You need to hook it up, just like you would for any other NiosII-based design. In fact, depending on your board, you may even need to add a simple delay reset circuit (like in the majority of the example designs), as well.
- slacker
