16 years agoproblem of load of zImage
please i have a problem when i would load
the kernel zImage in my NIOS II processor of the board DE2 r when i tape : [NiosII EDS]$ nios2-download -g /opt/altera9.1sp1/nios2-linux/uClinux-dist/images/zImage this message appea Using cable "USB-Blaster [USB 7-1.1]", device 1, instance 0x00 pausing target processor: not responding.resetting and trying again: failed
leaving target processor paused so if somebody have a solution ?
Did you configure the DE2 with correct sof?
Can you run the try out image? - Hippo - Altera_Forum
hello,
yes i use .sof nios2-configure-sof /opt/altera9.1sp1/nios2eds/examples/vhdl/niosii_cycloneii_2c35/full_featured/ niosii_cycloneii_2c35_full_featured.softhe mesage appears is
Wrong. That is for Altera NIOS 2c35 board, not DE2. Your sof, ptf must match your board.
Please check the try out page. http://nioswiki.com/operatingsystems/uclinux/tryoutuclinux - Hippo
