16 years agoproblem of load nios2-configure-sof with commande linux
hello,
i'm know in the last step to load the .sof ( nios2-configure-sof) in the board cyclone II 2c35 i followed the step indicate in: http://nioswiki.com/operatingsystems/uclinux/quartusforlinux but when i write this line [NiosII EDS]$ nios2-configure-sof bash: nios2-configure-sof : commande introuvable /opt/altera9.1sp1/nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured if somebody have any solution please ?4 Replies
You have to customize the n2sdk script for your particular system. Failure to do so will end up with paths being improperly defined or just not defined at all. I have successfully done this for many systems, Ubuntu/Xubuntu being the most recent.
Best Regards, -slacker - Altera_Forum
hello,
first thank's for the reponse, but i don't understand how i can change my n2sdk script. ******************************************************* #!/bin/bash# Run this for a Nios II SDK bash shellexport LM_LICENSE_FILE=1800@localhostSOPC_KIT_NIOS2=/opt/altera9.1sp1/nios2edsexport SOPC_KIT_NIOS2SOPC_BUILDER_PATH_91=/opt/altera9.1sp1/nios2edsexport SOPC_BUILDER_PATH_91unset GCC_EXEC_PREFIXQUARTUS_ROOTDIR=/opt/altera9.1sp1/quartusexport QUARTUS_ROOTDIRexport PERL5LIB=/usr/lib/perl5bash --rcfile $QUARTUS_ROOTDIR/sopc_builder/bin/nios_bash**************************************************************so what do you think i should change ? (it may be the perl5 for ubuntu i dont know the referance of perl) - Altera_Forum
Hi there,
you have to include the correct path. Search for nios2-configure-sof and include its path. For me the following works: PATH=$PATH:/opt/altera9.1sp2/nios2eds/bin Put it in homedir/.bashr (user) or /etc/bash.bashrc (global) - Altera_Forum
...or it could be something as simple as actually defining QUARTUS_ROOTDIR...
-slacker
