14 years agoproblem of large design with Qsys
Hi all, I'm designing a network of processor (Nios II) with Qsys 11.1. There are 32 niosII in my design and I use the ip-generate command-line. The issue is Qsys can't generate the sopci...
14 years agoI'd guess ip-generate is some kind of wrapper ??
You need to find the incantation that acually runs the jvm itself. If you type at the shell prompt: $ type ip-generate the shell should tell what it executes when you run ip-generate.
