16 years agoproblem of configuration of the kernel uclinux
problem of configuration of the kernel uclinux when i type the commande make menuconfig the messages appears and the new window also appear of configuration find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig config/mkconfig > Kconfig KCONFIG_NOTIMESTAMP=1 /opt/altera9.1sp1/nios2-linux/uClinux-dist/config/kconfig/mconf Kconfig Your kernel configuration changes were NOT saved. You have not saved your config, please re-run 'make menuconfig' make: *** [menuconfig] Erreur 1 and the new window appear of the configuration but there is Vendor/Product Selection ---> # select --- Select the Vendor you wish to target Vendor (analogdevice) ---> but i would have Vendor/Product Selection ---> # select --- Select the Vendor you wish to target Vendor (altera) ---> i would know if this problem produce because i use the nios2-linux-20090929.tar and not nios2-linux-20090730.tar
