19 years ago
Problem of CF card.(ctl=-1)
Hi, all.
I use Stratic2 board of ALTERA nios2.
I have a problem for compact flash.
Kernel detected CF card slot, but I receive following open messages.
I checked cause in this forum, and I got a relation remesseges for this cause.
However I didn't find out a adequate answer.
Could you please help me!
--------Openning Message -------------------------------
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 256 (order: 8, 1024 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 29852k/32768k RAM, 0k/0k ROM (1422k kernel code, 1177k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.1 $
ttyJ0 at MMIO 0x812110d0 (irq = 4) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <[email protected]>
eth0: SMC91C11xFD (rev 2) at 81200300 IRQ 5 [nowait]
eth0: Ethernet addr: 00:07:ed:0d:b5:29
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=-1
Unable to initialize compact flash card. Please re-insert
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 1056k freed (0x2174000 - 0x227b000)
Shell invoked to run file: /etc/rc
-------until here--------------------------------------------------------------
Thanks a lot.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
    Hi, guys.
    This is a additional infomation.
    As I received a messege of re-insert, I tried to re-insert CF card.
    And, I typed following command.
    /> mount -t vfat /dev/hda1 /mnt/cf
    mount: Mounting /dev/hda1 on /mnt/cf failed: No such device or address
    Thank you.
    Best Regards.
    Hi, all.
    I changed .sof file.
    So, Openning message changed like next.
    I have seen this messege in this forum, but there was not answer.
    Please help!
    CF: ctl=1
    hda: no response (status = 0xff), resetting drive
    hdb: no response (status = 0xff), resetting drive
    CF register fails
    Thank you.
    Hi, all.
    I got successful for CF card.
    I connected detect_n to CD1_N by the SOPC Builder, reset_n_from_the_cf to PIN_U3 by the Pin Planner.
    And, I made a .sof file and .ptf file again, and I got a new kernel.
    The cause is as follows.
    CF: ctl=1
    hda: SanDisk SDCFJ-32, CFA DISK drive
    ide0 at 0x81211100-0x81211107,0x81211138 on irq 7
    hda: max request size: 128KiB
    hda: 62720 sectors (32 MB) w/1KiB Cache, CHS=490/4/32
    hda: hda1
    Command: mkdir /mnt/cf
    Command: mount -t vfat /dev/hda1 /mnt/cf
