21 years agoproblem of building uclinux
hi
I met the following problem when I build uclinux with niosII ide: Kind Status Priority Description Resource In Folder Location Warning unused variable `fhp'[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/lockd/svcsubs.c] kernel_1c20 line 58 Kind Status Priority Description Resource In Folder Location Warning long unsigned int format, size_t arg (arg 7)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/base/dmapool.c] kernel_1c20 line 73 who can help me ,thanks.4 Replies
ok,I am success!
now I have run uClinux successfully on niosII (cyclone board)and configure my IP address on it.uClinux/Nios II --- Quote Start --- Altera Nios II support © 2004 Microtronix Datacom Ltd. On node 0 totalpages: 4096 DMA zone: 0 pages, LIFO batch:1 Normal zone: 4096 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 16 (order 4: 128 bytes) Memory available: 14596k/4096k RAM, 0k/0k ROM (1298k kernel code, 285k d Calibrating delay loop... 24.62 BogoMIPS Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) POSIX conformance testing by UNIFIX NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR ed:0b:0c:6c smc_probe: 50000 Khz Nios Using anticipatory io scheduler microtronix[mtd]: RAM probe address=0x200000 size=0x1ee000 Creating 1 MTD partitions on "RAM": 0x00000000-0x001ee000 : "ROMfs" microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 44k freed (0x1172000 - 0x117c000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 /etc/issue www.microtronix.com July 2004 Welcome to Linux on the Nios II Nios2 login: nios Password: Login incorrect /etc/issue www.microtronix.com July 2004 Welcome to Linux on the Nios II Nios2 login: nios Password: # ls ftp httpd# ifconfig eth0 211.65.88.227 netmask 255.255.255.128 eth0:PHY 100BaseT eth0:PHY Half Duplex# - Altera_Forum
yes,the next step is build a rw filesystem,that's very annoying http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
good luck http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
hi,tazok
do you know how to builder a rw file system? I am a newer, can you help me? thanks a lot. - Altera_Forum
--- Quote Start --- originally posted by xlking@Dec 6 2004, 04:30 AM hi,tazokdo you know how to builder a rw file system?
i am a newer, can you help me?
thanks a lot. --- Quote End --- To successfully build an rw filesystem copy the filesystem files on Compact Flash previously partitioned with an ext2fs on hda1, try mknod for all device in /dev directory, then specify the root=0301 in kernel config, recompile the kernel and upload it. Good Luck
