9 years agoProblem: NIOS II application fails to run, but runs in DEBUG mode
Hello, The problem is fully expressed in the title. Any ideas ? Thanks in advance.
8 years agoHi, have you solved this issue??
I've encountered the same issue here. I'm booting the Nios2/e from EPCQ. After power-cycling and then pressing reset the Nios2/e wont start. However if I do "Run as" --> "Run Configuration ..." as you described the processor launches without having clicked "Run". After having done this once I can freely close the 'Run Configuration' window. Press 'reset' and the processor will properly start. This works until I power-cycle the board. I also experimented with connecting to the processor without downloading any code. When I press the 'reset' button I see in the output that the processor properly jumps to the reset vector address, executes some instructions and after a while jumps to the address on internal ram (as it is supposed to do).
