20 years agoProblem mounting ext3 Compact Flash
I downloaded the linux tools from the WIKI website. I have followed the instructions listed in UClinuxDist, and CompactFlash. I added EXT2 and EXT3 support. The kernel & filesystem works fine with FAT and ext2 disks. But when I try to mount a Compact Flash (1GB) disk formatted with ext3, I get several errors and the system does not see the correct disk size. The disk was formatted on a Linux machine running Fedora Core 3. The e2fsprogs is version 1.35. I used the mkfs.ext3 /dev/hda1 to format the disk. The relevant boot-up messages: ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=11 hda: , ATA DISK drive ide0 at 0x80800000-0x80800007,0x80800038 on irq 7 hda: max request size: 512KiB hda: status timeout: status=0xd0 { Busy } ide: failed opcode was: 0x27 hda: drive not ready for command hda: 4294967295 sectors (2199023 MB) w/32767KiB Cache, CHS=65535/255/63 hda: status timeout: status=0xd0 { Busy } ide: failed opcode was: 0xef hda: drive not ready for command hda: cache flushes supported hda: status timeout: status=0xd0 { Busy } There are some other messages printed afterwards. I'm sure I did not something right in the kernel config, I hope somebody can help.2 Replies
Silly question... did you compile ext3 support into your uClinux kernel??
Cheers, - slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Oct 13 2006, 03:26 PM silly question... did you compile ext3 support into your uclinux kernel??cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18678)
--- quote end ---
--- Quote End --- Yes, I did. I just reformatted the disk for FAT. Windows XP is happy with the device I can write and read from it. Same under Fedora. But when I bootup the uClinux card, I get the same error messages. I'm very confused. Any ideas?
