19 years ago
Problem in using Avalon_Tristate_slave...
I am currently using " Altera Stratix 1S10 Development Kit".
In SOPC Builder, I wanted to connect my User Logic to Nios Processor through Avalon_Tristate_slave.
The Entity Interface in VHDL code of my User logic [Inverter]is:
entity pipeline is
Port ( clk : in std_logic;
reset : in std_logic;
cs : in std_logic; -- chipselect
wr : in std_logic; -- write
rd : in std_logic; -- read
Outen : in std_logic; -- outputenable
dio : inout std_logic_vector(31 downto 0)); -- Data Bidirectional
end pipeline;
Here, I tried to add this New Component in SOPC builder.
While editing the componet by "Component Editor" wizard, I have chosen Avalon_tristate_slave_0 in Interface-Tab.
Then in Signals Tab, Signal type option for this bidirection signal: " dio" is not indicating the type "Data". So by this, the Component is NOT Set as "OK" by Editor. So I am unable to proceed.
I have gone through the document "mnl_avalon_spec.pdf", there I found this is the minimum requirement of signals to be done, for Tristate Bus Interface.
Then What would be the problem, Can anyone help me out??
K V Naresh
    You don't really need burst.
    You shall start with a simple component, with two slave ports.
    One port s1 for output (from the view of CPU), and the other port s2 for input.
    s1--> user logic --> s2
    slave s1 pins: s1_writedata,s1_write,s1_waitrequest
    slave s2 pins: s2_readdata,s2_read,s2_waitrequest
    waitrequests are used for synchronize.
    Then the component can be accessed by CPU or DMA.
