20 years agoproblem in NIOSII IDE 5.1 Flash Program
Hello! I newly installed NIOSII_5.1 version. And tried Hello_led with NiosII evaluation Board(Cyclone_1c12_eval). It works fine until RUN AS. After programming the project through flash p...
20 years ago --- Quote Start --- originally posted by aforz@Feb 20 2006, 12:27 AM hello!
i newly installed niosii_5.1 version.
and tried hello_led with niosii evaluation board(cyclone_1c12_eval).
it works fine until run as.
after programming the project through flash programmer tool,
it does not work.
i expect that the led on the board are blinking sequencealy.
but no blinking.
there is no error message as bellow flash-program log;
please help!!!!!
"# ! /bin/sh# # this file was automatically generated by the nios ii ide flash programmer.# # it will be overwritten when the flash programmer options change.#
cd c:/altera/kits/nios2_51/examples/verilog/niosii_cyclone_1c12_eval/standard/so
ftware/hello_led_0/debug
# creating .flash file for the project
$sopc_kit_nios2/bin/elf2flash --base=0x00000000 --end=0x3fffff --reset=0x0 --inp
ut=hello_led_0.elf --output=ext_flash.flash --boot=$sopc_kit_nios2/components/al
tera_nios2/boot_loader_cfi.srec
# programming flash with the project
$sopc_kit_nios2/bin/nios2-flash-programmer --sidp=0x00801088 --id=2335580406 --t
imestamp=1129864794 --base=0x00000000 ext_flash.flash
using cable "nios ii evaluation board [usb-0]", device 1, instance 0x00
resetting and pausing target processor: ok
reading system id at address 0x00801088: verified
: checksumming existing contents
00000000 : reading existing contents
checksummed/read 64kb in 1.4s
00000000 ( 0%): erasing
erased 64kb in 0.4s (160.0kb/s)
00000000 ( 0%): programming
programmed 1kb +63kb in 1.0s (64.0kb/s)
device contents checksummed ok
leaving target processor paused
the above message indicates no error.
i assumed that flash programmed anyway.
when the *.sof file is newly loaded, then leds are blinking sequencely.
if reset button is pushed, blinking stops.
the board works well at niosii_1.1 version.
please help!!!!
aforz
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12803)
--- quote end ---
--- Quote End --- Hi!!!! I have found the reason of problem. It is caused by missing installing quartusII 5.1 patch. Thanks for your interesting. aforz
