16 years agoProblem in NicheStack TCP/IP
Hi, I'm trying to implement NicheStack TCP/IP in my project I used the Simple socket server example when the program runs It gives me the log file in the below : The problem is that the ...
16 years agoHi Daxiwen,
Thanks for your prompt reply. i am getting message like Hany Assasa's Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 *** tcp_sleep, OSMutexPend = 4 dtrap - needs breakpoint *** tcp_sleep, OSMutexPost(2) = 4 dtrap - needs breakpoint Created "simple socket server" task (Prio: 4) *** tcp_wakeup, OSMutexPend = 4 dtrap - needs breakpoint *** tcp_wakeup, OSMutexPost = 4 dtrap - needs breakpoint *** tcp_wakeup, OSMutexPend = 4 dtrap - needs breakpoint *** tcp_sleep, OSMutexPost = 4 dtrap - needs breakpoint *** tcp_sleep, OSMutexPend = 4 dtrap - needs breakpoint I want to clarify this is a bug bout the tcp_sleep() and tcp_wake() functions do not work properly for tasks that call select() because I read Slacker's reply, it seems like moving the task to different priority solved the issue. Could you please advice? Thanks, Carid
