12 years agoProblem in getting 1 usec Interval Timer to work using NiosII and QSYS
Hello everyone, Kindly guide me in resolving the following problem. I am unable to get the Interval timer to work for 1usec. It is working for 1msec. Case: I have a DE2115 kit. Using QSYS I h...
12 years agoI have not succeeded in working for 1 us with interrupt timer. The best I got is 15 us (without any other instructions)
How do you set the period : by the Qsys component editor? maybe you have forgotten the "unit" ;-) Instead of using variable to undersample the inteerupt, you should just toggle the led, and put a scope on it. NB : you can use the full controlled interval timer, then you can change directly the period.
