20 years ago
problem in designing custom peripheral
I designe a custom peripheral including a slave port with variable latency.So Its avalon interface signals is following:
clk,reset_n,ic_addr,ic_be_n,ic_cs,ic_data,ic_rd_n, ic_wr_n,ci_data,ci_valid,ci_wa
itrequest.
Signal ci_valid is used to inform nios2 of coming of valid read-data.Then I created a simple system to test the component but I get trouble .The signal ci_valid seems be ignored by System Generator Program because it is not wired to any other modules generated by Sopc Builder while both ci_data and ci_waitrequest is wired to a module named "custom_component_0_avalon_slave_0_arbitrator" . I think signal ci_valid should also be wired to that module but it is not.Why? What might I omit? help me~~~
custom peripheral name:custom_component
custom_component_0 is a instance and relative PTF section contained in system PTF file is as follows:
MODULE custom_component_0
class = "custom_component";
class_version = "1.0";
SYSTEM_BUILDER_INFO
Instantiate_In_System_Module = "1";
Is_Enabled = "1";
Clock_Source = "clk";
View
MESSAGES
Is_Collapsed = "1";
PORT_WIRING
SIMULATION
DISPLAY
SIGNAL x101
name = "custom_comp_hou/avalon_slave_0";
format = "Divider";
SIGNAL x102
name = "ic_addr";
radix = "hexadecimal";
SIGNAL x103
name = "ic_be_n";
SIGNAL x104
name = "ic_cs";
SIGNAL x105
name = "ic_data";
SIGNAL x106
name = "ic_rd_n";
SIGNAL x107
name = "ic_wr_n";
SIGNAL x108
name = "clk";
SIGNAL x109
name = "reset_n";
SIGNAL x110
name = "ac_ACK_addr";
SIGNAL x111
name = "ac_ACK_data";
SIGNAL x112
name = "sc_sa_tag_in";
SIGNAL x113
name = "sc_data";
SIGNAL x114
name = "ci_data";
SIGNAL x115
name = "ci_valid";
SIGNAL x116
name = "ci_waitrequest";
SIGNAL x117
name = "cs_addr";
SIGNAL x118
name = "cs_be_n";
SIGNAL x119
name = "cs_data";
SIGNAL x120
name = "cs_rd_n";
SIGNAL x121
name = "cs_wr_n";
SIGNAL x122
name = "cs_tag";
SIGNAL x123
name = "ca_empty";
SIGNAL x124
name = "ca_wr_n";
SLAVE avalon_slave_0
SYSTEM_BUILDER_INFO
Bus_Type = "avalon";
Address_Width = "26";
Address_Alignment = "dynamic";
Data_Width = "8";
Has_Base_Address = "1";
Has_IRQ = "0";
Setup_Time = "0";
Hold_Time = "0";
Read_Wait_States = "peripheral_controlled";
Write_Wait_States = "peripheral_controlled";
Read_Latency = "0";
Max_Pending_Read_Transactions = "2";
Is_Printable_Device = "0";
Is_Memory_Device = "1";
MASTERED_BY cpu_0/instruction_master
priority = "1";
MASTERED_BY cpu_0/data_master
priority = "1";
Base_Address = "0x00000000";
IRQ_MASTER cpu_0/data_master
IRQ_Number = "NC";
PORT_WIRING
PORT ic_addr
width = "26";
width_expression = "";
direction = "input";
type = "address";
PORT ic_be_n
width = "1";
type = "byteenable_n";
PORT ic_cs
width = "1";
type = "chipselect";
PORT ic_data
width = "8";
type = "writedata";
PORT ic_rd_n
width = "1";
type = "read_n";
PORT ic_wr_n
width = "1";
type = "write_n";
PORT clk
width = "1";
type = "clk";
PORT reset_n
width = "1";
type = "reset_n";
PORT ac_ACK_addr
width = "1";
type = "export";
PORT ac_ACK_data
width = "1";
type = "export";
PORT sc_sa_tag_in
width = "2";
type = "export";
PORT sc_data
width = "8";
type = "export";
PORT ci_data
width = "8";
direction = "output";
type = "readdata";
PORT ci_valid
width = "1";
type = "readdatavalid";
PORT ci_waitrequest
width = "1";
type = "waitrequest";
PORT cs_addr
width = "26";
type = "export";
PORT cs_be_n
width = "1";
type = "export";
PORT cs_data
width = "8";
type = "export";
PORT cs_rd_n
width = "1";
type = "export";
PORT cs_wr_n
width = "1";
type = "export";
PORT cs_tag
width = "2";
type = "export";
PORT ca_empty
width = "1";
type = "export";
PORT ca_wr_n
width = "1";
type = "export";
COMPONENT_BUILDER
AVS_SETTINGS
Setup_Value = "0";
Read_Wait_Value = "1";
Write_Wait_Value = "1";
Hold_Value = "0";
Timing_Units = "cycles";
Read_Latency_Value = "0";
Max_Pending_Read_Transactions_Value = "2";
external_wait = "1";
WIZARD_SCRIPT_ARGUMENTS
hdl_parameters
flag_tag = "2'b00";
HDL_INFO
Synthesis_HDL_Files = "__PROJECT_DIRECTORY__/custom_component.v,
__PROJECT_DIRECTORY__/custom_component_0.v";
