20 years ago
Problem in booting the kernel
Hello everyone. I am a newbie in uclinux.
I follow the UClinuxDist in
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
compile the kernel and download it.
In the uart terminal, it's displayed
"Uncompressing Linux... Ok, booting the kernel."
and nothing more.
I don’t know how the uclinux works.
Is there something wrong with boot process? Or I must use u-boot to boot the kernel?
Or the setting of the kernel is not correct?
thanks!
The following is what i have done.
I just want to test the uclinux on the sdram, so I didnot use the u-boot as smcnutt recommends.
QuartusII 5.0, NiosII5.0
The board is UP3 (sls.com) with 2MByte flash, and 8MByte SDRam.
http://www.slscorp.com/up3support/tutorial...c6%20manual.pdf (http://www.slscorp.com/up3support/tutorials/up3-1c6%20manual.pdf)
and I test the sdram and the flash with the design example from sls.com.
http://www.slscorp.com/up3support/tutorials/ref_design.zip (http://www.slscorp.com/up3support/tutorials/ref_design.zip)
First, I download and install the nios2linux-1.4.zip from the forum, and follow the “Linux Quick Start Guide.pdf” to compile the kernel under the nios2 IDE. It’s success. But I don’t know how to download it to ram.
Then, I compile the kernel following the instruction in UClinuxDist under Ubuntu
using uClinux-dist-test-20060511.tar.bz2 and uClinux-dist.diff.gz from
http://nioswiki.jot.com/wikihome/operating...ux-dist.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist.diff.gz)
and download the kernel in win-xp, with nios II SDK shell. It shows the zImage is download to 0x00500000. The display "Uncompressing Linux... Ok, booting the kernel."
Final, I try the method in
http://nioswiki.jot.com/wikihome/operating.../buildrootguide (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/buildrootguide)
and build the kernel with:
build0411.zip
uClibc-0.9.29-pre,busybox-1.1.1-pre0
binutils-2.15.tar.bz2
gcc-3.4.6.tar.bz2
linux-libc-headers-2.6.11.0.tar.bz2
buildroot-20060320
uClibc-20060320
busybox-20060320
and the uart terminate display the same.
1 Reply
    hi hammer
    If u want to run Linux on flash , then for store image into flash you have to store u-boot with some changes or u have to make new the sysem through SOPC builder with CFI-coponent.
    but just if u want to run linux from sdram ,then first compile kernel with required configuration as per“Linux Quick Start Guide.pdf” and then run it.
    it will boot through jtag console.
    --First, I download and install the nios2linux-1.4.zip from the forum, and follow
    --the “Linux Quick Start Guide.pdf” to compile the kernel under the nios2 IDE. It’s
    --success. But I don’t know how to download it to ram.
