13 years agoProblem generating new .sof file with unlicensed IP : "NIOS II processor"
I'm using Quartus II to generate a new .sof file that includes a NIOS II processor core, but when I start assembler to construct my new .sof file I have the problem of license (like in the atta...
13 years agothe generated file will be called xxxx_time_limited.sof
You can use it as a regular .sof file, but you will have a message window saying you are in evaluation mode. Keep that window open and your design will work fine. You also won't be able to flash your design as long as you don't buy the licenses.
