21 years agoProblem Downloading in Nios IDE
I am trying to program is simple "Hello World" program into a Nios II running in a Cyclone (EP1C6T144) which is on a custom board. I'm using Quartus 5.0 and the USB byte-blaster. When I select "R...
21 years agoI layout the JTAG as:
TCK pulled low with 10K ohm TMS,TDI pulled high with 10K ohm TDO floated ( I saw someone pllued high) other signals for downloads: FPGA_CONF_DONE,FPGA_STATUSn pulled high with 10K ohm I tested TDO pllued high, It worked, too. Which one is the best choice?
