21 years agoProblem Downloading in Nios IDE
I am trying to program is simple "Hello World" program into a Nios II running in a Cyclone (EP1C6T144) which is on a custom board. I'm using Quartus 5.0 and the USB byte-blaster. When I select "R...
21 years agoIt looks, to me, like you've not programmed your FPGA or you have no debugger built into your processor, though you clearly state that you have. What does a "jtagconfig -n" command return from within the SDK shell? You should see something like this:
$ jtagconfig -n
1) USB-Blaster
020840DD EP1C20
Node 11104600
Node 0C006E00 The two "nodes" listed, above, are the debugger and the jtag_uart, in my case. Also, make sure you're not using an OCP version of the processor, as that requires that you keep the programmer open. Cheers, - slacker
