21 years agoProblem Downloading in Nios IDE
I am trying to program is simple "Hello World" program into a Nios II running in a Cyclone (EP1C6T144) which is on a custom board. I'm using Quartus 5.0 and the USB byte-blaster. When I select "R...
21 years agoHi Danny,
My two cents would be to: 1. Try a JTAG if possible and see if you get the same message 2. Try rebooting your machine, sounds hokey, but I have seen this work 3. Try a different CPU, Like The Lower Performance/ Also play wiht debug levels 4. Make sure memory is targeted correctly, check system properties. -Baycool
