20 years agoProblem dloading vmlinux to 2C35
Hi, I was trying to download the vmlinux.flash image to the board and received this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processo...
20 years agoThere may be problem in initramfs image. rebuild it.
rm -rf ~/rootfs
cp -a ~/buildroot/build_nios2/root ~/rootfs
cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list
rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot
cp ~/download/inittab etc# clean headers for uClinux-dist
cd ~/buildroot/build_nios2/staging_dir/include/linux
rm config.h autoconf.h
touch config.h autoconf.h
cd ~/linux-2.6.x# rebuild image for initramfs
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
