20 years agoProblem dloading vmlinux to 2C35
Hi, I was trying to download the vmlinux.flash image to the board and received this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processo...
20 years agoHi hippo,
Thanks, I got this after opening up nios2-terminal- <div class='quotetop'>QUOTE </div> --- Quote Start --- Linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.5)# 6 Sa t Mar 4 20:28:04 EST 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5456k/8192k RAM, 0k/0k ROM (704k kernel code, 1912k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes)[/b] --- Quote End --- seems like linux is now on the board but it seems to go into some kind of weird loop where it keeps outputting the following: <div class='quotetop'>QUOTE </div> --- Quote Start --- Free pages: 0kB (0kB HighMem) Active:1023 inactive:148 dirty:0 writeback:0 unstable:0 free:0 slab:191 mapped:0 pagetables:0 DMA free:0kB min:0kB low:0kB high:0kB active:4092kB inactive:592kB present:8192k B pages_scanned:2552 all_unreclaimable? no lowmem_reserve[]: 0 0 0 Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pag es_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 HighMem free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pa ges_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 0kB Normal: empty HighMem: empty oom-killer: gfp_mask=0xd2 DMA per-cpu: cpu 0 hot: low 2, high 6, batch 1 cpu 0 cold: low 0, high 2, batch 1 Normal per-cpu: empty HighMem per-cpu: empty[/b] --- Quote End --- thanks in advance!
