20 years agoProblem dloading vmlinux to 2C35
Hi, I was trying to download the vmlinux.flash image to the board and received this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processo...
20 years agoI just tried that but I'm still getting the same error though
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: not responding Resetting and trying again: FAILED Leaving target processor paused I'm trying this with the standard.sof from the CD but I'm using the DE2 Cyclone II 2C35 board which doesn't have ddr_sdram. I assume if I create my own design (ie .sof and .ptf) and use that .ptf I should be able to get the sdram option during hwselect when compiling the kernel? Currently, I don't have an option for sdram with the std_2C35.ptf and it instead only gives the options for ddr_sdram, ext_ssram and epcs_controller for selecting a device ot execute the kernel from.
